replace csp?
Old Oct 27, 2009 | 08:19 PM
WMDPSD's Avatar
WMDPSD
replace csp?
Has anyone every replaced a crank position sensor on an 04 6.0 6spd.? It has been sorta hard starting since he got the truck, and he has been getting a lot of code for the cps. When he clears them they come back. He is running edge evolution (100 hp). It mostly just need to know where it is so I can look at it. Thanks for any help in advance.
p.s. It has 130,000+ miles
Old Oct 28, 2009 | 07:22 AM
dcaddi2's Avatar
dcaddi2
Page 12: Component Locations
Old Oct 29, 2009 | 08:03 PM
WMDPSD's Avatar
WMDPSD
do they ever go bad?
Old Oct 29, 2009 | 08:12 PM
cheezit's Avatar
cheezit
not often. we see cam sensors but not many of them either. you can hook up an osilicope to it and check the pattern.
Old Oct 29, 2009 | 08:42 PM
WMDPSD's Avatar
WMDPSD
but I think that the fact he keeps getting the code, it would mean it is bad?
Old Oct 29, 2009 | 09:02 PM
cheezit's Avatar
cheezit
no that means he trys to crank the engine 10x and it wont start. there are a few ckp (what you are calling a cps is really a ckp) dtc wich one is it.
also there is a cmp sensor is there a code setting for that as well at the same time.
any other codes?
If it were only a matter of O theres the code it needs that part everyone would be able to do my job.
