2005 F250 Horn
2005 F250 Horn
My horn on my 2005 F250 would not stop after I gave it a quick tap when someone cut me off. So - I proceeded to press and bang on it until it did. Since that time, it will not work at all.
I have replaced the horn switch but it still does not work. I've seen mention of the clock switch?
Does anyone have a troubleshooting methodology I can follow to troubleshoot/verify the horn switch is 'good'?
Thank you,
Scott
Thank you,
Scott
As Hartwig stated change the horn contact. If the cruise control works but the horn doesn't it has to be the horn contact.
https://www.ebay.com/itm/NEW-OEM-STE...gjWj#vi-ilComp
https://www.ebay.com/itm/Ford-Super-...EAAOSw3~tZbjKL
yes, both were burned
it happened to me twice in a row that the horns were internal destroyed. So i opened the horns the second time. The horn contact was the problem on the airbag. The horns were horning themselves "to death". I don't have the truck at my house, though. So I couldn't hear it.
So - the other night, the horn just started going off in my driveway. I wound up removing the fuse to stop it. I took it to a repair shop as I needed a quote for my A/C and they diagnosed it as being the "switch inside air bag" needs to be replaced.
Any thoughts on what the "switch" is they mentioned? They said the horn contact membrane did not need to be replaced. So - I have asked if there is a part number but thought maybe someone here might know what they are referring to.
Regards,
Scott
Regards,
Scott
Just to be clear - the horn pad you mention is the horn contact membrane (for example - https://www.amazon.com/Dorman-924-90.../dp/B01CS3KKIS) - correct?
BTW - love your truck/camper
Regards,
Scott
Regards,
Scott
