Best Frame Paint?
Old 10-20-2009, 06:23 PM
Roger T. Pipe's Avatar
Roger T. Pipe
Roger T. Pipe is offline
Best Frame Paint?
I'm in the process of stripping/sandblasting the frame on my '96 250. I want to paint it with a rust preventitive paint. What are your opinions on the type to use? I know POR15 is great, but I've heard it's not the last word in paints. Any opinions? I'm looking for a semi-gloss black frame finish.
Roger
Old 10-20-2009, 06:32 PM
wolfsmurf's Avatar
wolfsmurf
wolfsmurf is offline
a friend of mine was just painting some chassis parts from his rice burner,imeanhonda.
last week and he painted the arms with a paint purchased from advance auto. brand is ht something, its an epoxy paint, it says its for shocks/struts. the reason i am typing all this is because he painted the a-arms with this stuff and then decided to put in the control arm bushings and they wouldnt fit because there was paint in the holes. he tried scraping some off with his knife and it wouldnt budge! he then pulled out a wire brush and it still wouldnt come off. he ended up with his dremel and about 10 minutes later had it all clean again. thats some tough paint.
Old 10-20-2009, 07:02 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Eastwood chassis black for a resto.I would use Rustolium black for a driver
Old 10-20-2009, 07:25 PM
TNT1968's Avatar
TNT1968
TNT1968 is offline
POR-15 is good stuff and about bulletproof but it's murder on your spray gun if you don't clean it well immediately after spraying. I think you can brush it on and it will level itself as well. It's shiny black but you can spray a chassis black over it if you want a flatter black.
Old 10-20-2009, 07:27 PM
Roger T. Pipe
Diesel Brad I saw your resto pics and the frame looks unreal! That's pretty much how I'm trying to get mine to look. The only thing is, is Rustoleum all that tough? I know POR15 is like ceramic once it dries. Remember, I'm in the northeast and the road salt here is brutal. So I'm not only looking to get it good-looking, but I need it protected. How do you think the Rustoleum does in that department?
Rog
Old 10-21-2009, 03:58 AM
Diesel_Brad
My boss always does his pick up frames in rustolium. He does his every other year. But for prep he just powerwashes the frame. If he would actually sand and prep the frame correctly it would last much longer.
As for the POR-15. my brother needle scaled his frame last fall. Then wipped it down w lacquer thinner. then 2 coats of POR. He has little rust spots comming thur all over the frame after one winter. And it gets powerwashed for about 20 min after every snow storm
Old 10-21-2009, 05:21 AM
TexasGuy001's Avatar
TexasGuy001
TexasGuy001 is offline
I thought you were supposed to paint over the POR 15?
I have seen people use impliment paint for tractors.
Old 10-21-2009, 05:28 AM
greyghost85's Avatar
greyghost85
greyghost85 is offline
they advertise rustbullet on here. wonder how well it works?
Old 10-21-2009, 05:36 AM
TexasGuy001
I actually have the sample kit from Rust Bullet. Its 2 small cans about a pint each or something like that. I haven't used them on anything yet. I know that I have read on several forums that people like it.
Old 10-21-2009, 05:47 AM
greyghost85
cant you sleep,for worrying about your frame rusting?...lol i plan to do my frame in the near future, so your topic was of interest to me. i have a flat bed so a lot of the frame shows.
Old 10-21-2009, 05:50 AM
greyghost85
sorry,tg1. confused you with roger t
Old 10-21-2009, 06:01 AM
TNT1968's Avatar
TNT1968
TNT1968 is offline
If you use metalprep on the frame after sandblasting, then POR15 or equivalent 'm sure you'd be ok.
Old 10-21-2009, 07:12 PM
Diesel_Brad
POR 15 is ok untopcoated on a frame. It needs to be topcoated where the sun will get to it
Old 10-21-2009, 09:57 PM
Pkupman82's Avatar
Pkupman82
Pkupman82 is offline
When I did the frame on my 84 F150 restoration I had it completely sandblasted, went with a zinc oxide primer and four coats of Rustoleum gloss black. I swear by Rustoleum, it's the most affordable protection money can buy. I use it on all my undercarriage components, floor boards, etc. In fact tonight I just finished repainting my snow plow with Rustoleum. From my own experiences it looks good, holds up pretty well to the elements and doesn't cost an arm and a leg.
Old 10-22-2009, 02:15 AM
TexasGuy001
I didn't know that. Most of the time I thought people painted over it.
Quick Reply: Best Frame Paint?
