Which shocks for DJM drop beams and drop shackles?
Which shocks do I need to use for the front end with the drop beams and the rear end with drop shackles? Do I need to buy DJM shocks or can I use another brand? If I can use a different brand which shocks would you guys recommend? A part number maybe? Just a regular street driven truck so not doing anything extreme. Thanks for any advice.
i dont know if this will help you but heres somthing about depending on which kind you have
http://www.djmsuspension.com/Instruc...s/HS1130-4.pdf
and it says call for shock specification on the parts sheet they have.
