AO Code?
Old Oct 21, 2009 | 10:21 PM
Talyn's Avatar
Talyn
Glad you guys know about this.
I was speculating, I have no clue how the system works except that oil pushes the fuel.
Old Oct 21, 2009 | 11:06 PM
strokin'_tatsch's Avatar
strokin'_tatsch
wow, i just got really confused for a second.. i read it 3 times tho, i'm starting to figure it out.. LoL.
Old Oct 21, 2009 | 11:09 PM
Talyn's Avatar
Talyn
I'm still trying to figure out why there are 2 holes.
Old Oct 21, 2009 | 11:18 PM
strokin'_tatsch
i'm still trying to figure out why there arent more!! LoL. my guess is you have 3000 psi of oil trying to go through such a small hole. not going to happen, but makes it easier to get that oil in the injector with more holes. thats what i gather from it. guess thats why jim said they put more holes in there or make those bigger when they use really big injectors
Old Oct 22, 2009 | 08:47 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
The 2 holes on the AA are 90* from the oil
port in the head.
Maybe I wasn't clear enough. All A codes have ONE hole on the left side, 9:00 position, right where the main oil supply from the head is. The AO has the second hole 90* from that at 12:00, AA, AB and AD have the second hole 180* from that at 3:00.
You'd know what we're talking about if you had an injector in yoru hand.
William should know in a day or 2.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old Oct 22, 2009 | 10:18 AM
Talyn's Avatar
Talyn
I understand where they are on the injectors.
What I am missing is what goes on in the head on the engine and how the oil channels work in there.
I'm guessing oil flows in one, and out the other to the next injector.
or what is the 2nd hole for?
Obviously it comes in at 9. So where does the other hole take the oil?
Old Oct 22, 2009 | 10:19 AM
Talyn's Avatar
Talyn
Old Oct 22, 2009 | 11:30 AM
wildstang's Avatar
wildstang
VT Chapter Ldr
Hey Talyn, stop padding up your post count with double posts.
Old Oct 22, 2009 | 04:44 PM
Talyn's Avatar
Talyn
I dont do it on purpose!
i click send once, I duno what the deal is.
Old Oct 22, 2009 | 07:01 PM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
Picture the oil rail in the head like a pipe running front to back. Then, put ports in the pipe coming out the side. 4 of them to feed each injector. With the injector installed in the head, there is a chamber (the notch in the middle of the injector where you will find the 2 supply holes) and the HPOil port in the head is right at this chamber/notch. It's in this chamber that the holes are 180* apart that I am referring to. Oil goes in BOTH holes into another 'chamber' in the injector just below the Poppet Valve. When the solenoid energizes it lifts the Poppet valve up off the lower seat and into it's upper seat, allowing that oil to then go upwards, make a 180* internal turn into another passage down to push the Intensifier Piston, which pushes the Plunger, which pushes the fuel out.
Once the 'pushing of the fuel' is complete and the solenoid de-energizes, the Poppet valve rests back down exposing the upper port, and the oil that filled the Piston chamber to push it down, then is pushed back up through the passage (by the Plunger Spring) and is exhausted through the port and alum spout on the injector and goes back to the crankcase via the valve cover area.
Simple, huh?
This is precisely why it is so difficult to make lots of power with this type of fuel injection system.
Leave it to Ford to find the most complicated injector designed by man to put in their trucks...
Look at the pic below:
The Purple channels are the oil passages, the one on the left goes from the Poppet Valve to the Piston. The angled one on the right has an identical hole 180* away, leads from head supply to chamber below Poppet. The 2 Purple channels are 90* apart, but FWIW the channel shown on the left is actually 180* from where it should be. They put the injector together 'wrong' to show you the passages and other features.
__________________
Old Oct 22, 2009 | 07:15 PM
cowmilker08's Avatar
cowmilker08
Just a WAG here, but maybe the holes are spaced at 180* so that you don't have oil sitting on on side of the injector forever, turning into sludge and whatnot.
Old Oct 22, 2009 | 08:47 PM
wildstang's Avatar
wildstang
VT Chapter Ldr
Talyn, just kidding, I like to give people a hard time. Happens to me once in a while.
Old Oct 22, 2009 | 10:36 PM
  #28
Talyn's Avatar
Talyn
you were giving me a hard time?
Old Oct 23, 2009 | 07:47 AM
  #29
wildstang's Avatar
wildstang
VT Chapter Ldr
Not in a mean way, just joking.
Old Oct 23, 2009 | 09:08 AM
  #30
Talyn's Avatar
Talyn
You were joking?
