Ford 302 Water Pumps - Right or Left Outlet
Old 10-05-2009, 07:51 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by reg1952
The old 302 pump from the 72 engine had the inlet on the right and the shaft was lower in the casting.
Which 1972 302 engine might that be?
D6ZZ8501B .. 302 Waterpump / Replaced: DOAZ8501F & DOOZ8501C.
Fits: 1969/79 F100 // 1975/79 F150 // 1970/79 Passenger Cars except 1975/78 Mustang II & 1979 LTD.
D3UZ8501A .. 289/302 Waterpump / Replaced C5AZ8501H.
Fits: 1965 289 from 8/23/1964, 1966/68 289.
Fits 302: 1968/69 Galaxie/LTD/Mustang/Fairlane/Torino/Falcon // 1966/77 Bronco // 1969/74 Econoline.
Old 10-05-2009, 10:39 PM
51dueller's Avatar
51dueller
51dueller is offline
The only 1970's (and the very first) cars to have serpentine belts were the 1979 LTD/Mercury Grand Marquis with 302/351W's.
The 1979 Ford Mustang had a single serpentine belt with an actual tensioner. The LTD was just like a V belt setup as set tension with the accessories.
Old 10-06-2009, 03:40 AM
NumberDummy
You re correct about the Mustang, I should have looked past the LTD which is listed first in the catalog.
A serpentine belt has a JK6 Motorcraft part number prefix.
1979 Mustang 302 Motorcraft JK6842 w/o A/C / JK6942 w/A/C.
1979 LTD 302/351W Motorcraft JK6502, JK6510, JK6512 it depends on which alternator the car has, wheter a 302 or a 351W.
There's also a T/E belt and an A/C belt, not serpentine.
Old 10-06-2009, 06:07 AM
fatfenders's Avatar
fatfenders
fatfenders is offline
Yes, that is exactly what my LTD setup is like. As Number Dummy said, the AC compressor (which I did not use) takes a separate V belt. The AC compressor is huge and not what I would suggest for a street rod. The WP, ALT and PS pump drive off a single serpentine. It looks pretty clean, and I liked the "modern" style accessories I could actually find locally new if I needed to.
The Foxbody mustangs through 1993, and SN95 (94-95) Mustangs are good donors. You can delete smog and AC by simply re-routing a shorter serpentine belt. Aftermarket accessory delete pulleys are also available. On my 94, deleting the AIR pump puts an odd angle on the alternator. The delete pulley fixes it.
dethomson
19
07-03-2022 09:22 PM
cole.jace
63
04-21-2011 02:52 AM
GreatNorthWoods
05-14-2010 07:13 PM
Michigan Rick
37
04-12-2010 08:57 PM
Mohave
Modular V10 (6.8l)
09-11-2009 11:07 AM
Quick Reply: Ford 302 Water Pumps - Right or Left Outlet
