General Automotive Discussion
Keep getting 2 codes
Old Sep 26, 2009 | 01:45 PM
03scf250's Avatar
03scf250
My 01 windstar keeps throwing 2 codes. P0171 (system lean bank 1) and P0174 (system lean bank 2) What could be some possible causes . It runs fine no loss of power or hesitation what so ever. I'm thinking maybe O2 sensor, clean maf sensor, clean throttle body, and ???? Any advice I can get would be appreciated.
Old Sep 26, 2009 | 01:57 PM
bodabdan's Avatar
bodabdan
Veteran: Navy
Leak on the intake air piping maybe?
Old Sep 29, 2009 | 07:01 PM
03scf250's Avatar
03scf250
Took it to a friends garage since I have no free time. Got the call today it's the intake gasket leaking by cylinder 1.
Old Sep 29, 2009 | 07:33 PM
bodabdan's Avatar
bodabdan
Veteran: Navy
I guess it's good that the problem is found, would be better if it was just a vacuum line though.
Old Sep 30, 2009 | 09:17 AM
jimbeamalki's Avatar
jimbeamalki
Suggest you go to AutomotiveForums.com and search the Windstar forum. Very common problem--pretty sure you're supposed to replace all the isolator bolts and the front valve cover when you do the gasket. Not for sure if this pertains to 2001 or not.
Old Oct 4, 2009 | 06:58 PM
03scf250's Avatar
03scf250
Intake gasket set was changed definate crack in it. Bad news was it still was missing. After a fair amount of testing the coil was found to be weak on the towers for cylinders 1 2 3. The 4 5 6 towers showed full juice, slapped a new coil on and tada fuel milage is back and runs great again. Gets the wife back in a better mood. So now I can get back to working on the 78 in my sig.
EDsurvivor
Garage & Workshop
Mar 26, 2017 02:48 AM
Bruno Gouveia
2004 - 2008 F150
Mar 22, 2017 01:06 PM
WhyFord
163
Feb 17, 2017 07:49 PM
Wildboy402
2004 - 2008 F150
Dec 24, 2015 12:42 AM
mattymax
Dec 20, 2015 10:13 PM
