Code P0307
Old Sep 16, 2009 | 04:20 PM
happeetxn's Avatar
happeetxn
Code P0307
Howdy all,
My wife's CEL (Her vehicle, 2003 5.4L, 4x4, EB Expy) came on and long story short I got a code P0307 -Cylinder 7 misfire.
So my question is which cylinder is #7 and is there any way to determine what is bad, i.e COP, wire, plug, or injector?
I read the write up for the COP replacement and will print this off prior to making the repair.
Thanks for the help.
Craig
Old Sep 16, 2009 | 09:48 PM
alloro's Avatar
alloro
Swapping the COP, plug, or injector to different cylinders and seeing which cylinder the misfire moves to, is really the only sure way to know which component is the problem.
Cylinder layout:
Back of engine
|-4--8-|
|-3--7-|
|-2--6-|
|-1--5-|
Front of engine
Old Sep 17, 2009 | 01:30 AM
happeetxn's Avatar
happeetxn
Thanks for the reply.
Craig
Old Sep 19, 2009 | 12:47 PM
happeetxn's Avatar
happeetxn
Cylinder layout:
Back of engine
|-4--8-|
|-3--7-|
|-2--6-|
|-1--5-|
Front of engine
It appears that it was the COP. Replaced it and everything seems back to normal. The job wasn't near as bad as I thought it might be. Thanks to the member who did the write up on the COP replacement.
A concerning find was that the boot on the COP and the exterior of the plug had a lot of rust on them. I took pics and will post them later.
Now a follow up question. Do you wait for these to go out or do you just start replacing them? The plugs need to be changed out around by now if the original owner didn't do it right? The truck now has 110,000 miles on it, and maintenance has been done regularly to the best of my knowledge.
Craig
Old Sep 19, 2009 | 12:57 PM
happeetxn's Avatar
happeetxn
duplicate post.....
Craig
Old Sep 19, 2009 | 07:30 PM
alloro's Avatar
alloro
The rust on the plug and boot was because water got down into the plug hole. This usually is a sign that the boots are old and need replacing.
When I had a COP go out I replaced at 8 at the same time and kept a few of the old ones as spares. The plugs are supposed to be changed at 100K miles, so you're due for a set.
Old Sep 20, 2009 | 08:59 AM
happeetxn's Avatar
happeetxn
Any particular mods to do when I do this? Anything else I should consider doing while I am under the hood?
Thanks for the input.
Craig
Old Feb 12, 2010 | 11:16 AM
happeetxn's Avatar
happeetxn
Have used the info (specifically cylinder order) several times now. Just want to extend a big Texas thank you to Alloro for providing it.
Craig
Old Oct 2, 2012 | 10:20 AM
peakay's Avatar
peakay
Just wanted to also say thanks for this helpful post
SnowPlowDriver
Feb 13, 2017 06:11 PM
brandonnys
Modular V8 (4.6L, 5.4L)
Aug 17, 2015 09:29 AM
dockrocker
Feb 26, 2014 11:53 AM
SteevenH
1997 - 2003 F150
Jan 20, 2013 07:50 PM
inalabama
Apr 6, 2011 09:10 PM
