Hey Guys,
I'm in the process of rebuilding my 390. I'm looking for solid lifter pushrods. A couple are showing small crack's at the ball adjuster end. My searches haven't turned up anything useful yet. I got a set from Summit which aren't correct. The cup end is too small. Any info on a possible supplier would be helpful.
Comp pushrods are just fine. What kind of rockers are you running?
I'm using stock rocker arms, except they have solid spacers. The ball on the adjuster is approx .360 OD . The ones Summit sent were approx .310 ID in the cup.
I found a set locally at PAW yesterday afternoon and was able to pick them up...
