08 dif cover bolts
Thanks guys, I got 1 1/2 ss bolts.
I put one of my stock bolts through it just the very very very tip hung out the bottom, and the stocker is 3/4 iches long and the stock dif cover is paper thin lip, so I figured about all of the stock bolt went into the dif so I got bolts twice as long, If need be i can get a lock washer and washer to shim it out a little. I painted it black today and filed the edges to look like a mag hytec kind've and got ss round bolts that use an allen key. Should look good.
Pics will come beg on next week
sounds like it should look good Kenny, I painted mine a light grey to kind of look like the raw aluminum but I thought about doing just what you did. Can't wait to see the pics. I do remember someone else who used 1 1/2" bolts and they were a little long and had to use an extra washer or 2 but then all was good.
