There is fuel in bowl when lid off, and running. Tighten lid up and only runs for 5 mins aprox. Is there a sensor or something that tells it it needs fuel. Any help would be great thks in advance
nope, should be filling all the time, any excess goes back to the tank..... either your pumps to weak to push it or you got other issues... how olds the fuel filter?
Okay replaced lift pump, worked for about 15 mins, then died again. when it dies its not lit out of fuel but computer shut down. What sensors control fuel and maybe oil to injectors. Any help would be great thks Robbi
Okay I think I have it now the ICP is bad. Now Ford wants 370 and International wants 170. Is there cross over numbers to get it from Napa? Thanks to everyone that helped and this site is very helpful and it rocks
Don't forget to add "Reputation Points" to the folks that helped you. Click on the "Heart with the green dot" in the upper-right corner of the post that was helpful to you. Check the "I agree" section and add a comment.
Okay that didn't help, but it was worth a try. This time I had a hard time starting...problem was forgot to plug in large wire harness on side of fuel bowl. Now this time I noticed a sensor on bottom of fuel bowl. What does it do. Thanks for everything in advance..
did you check that screen in the FPR? if its plugged it wont purge air from the filter canister.and youll starve it and it will run like crap and die. you did say you had the filter open, so i was just wonderin...
