Sponsored by: Real Truck
undercoating
Old Aug 24, 2009 | 02:18 AM
78bigbronco's Avatar
78bigbronco
Question undercoating
Not really sure what I should do here. My 09 is less than 2 months old. It did not come with any undercoating. To be honest I read many comments suggesting undercoating is bad. I am wondering what can be done to help prolong the life of everything down below. I plan on keeping this rig till it falls apart, so the later that happens the better. I'd love to have everything line-x coated but I figure the cost (if they would even do it) I wouldnt be able to afford right now. Anything else people reccomend? DIY undercoating? Extra frame paint? One of my friends says every oil change he takes the used oil into a spary bottle and sprays the whole underside. Sounds a bit to messy for me.
Old Aug 24, 2009 | 02:57 AM
78_f800crewcab4x4's Avatar
78_f800crewcab4x4
anything you spray under there is better than nothing. the bed liner you buy in the rattle can might work ok. I would lay a layer of black rustoleum onto the frame if you need to go cheap. I need to do that to my '02 before too long. You sure cant beat shooting oil under there! lol thats what i did to my '73s body when i moved to the coastal area as a temporary rust stop until i can afford to coat it right.
Old Aug 24, 2009 | 08:36 AM
beached350's Avatar
beached350
Mine is 1 month old with 450 miles. I went underneath with black high gloss spray cans from Ace. Stuff dries real fast. I did the driveshafts, and anything else that didn't have paint.
Old Aug 24, 2009 | 08:58 AM
wideglidewoody00's Avatar
wideglidewoody00
On my wife's 02 FX4 her doors where the outside door panel wraps under at the bottom, the paint started bubbling after three years and then the rust started. I didn't want to use the used motor oil on a white truck so I spray WD 40 in the door drain holes and let it drain out the other end of the door, it stopped the rust dead. I do this every time I change her oil. I do the same on my F-250. On my truck I used Herculiner and coated the inside of the rear box panels, then recoated everything with spray can undercoat as far up as I could reach and over the wheel wells I put used motor oil. Have some rags ready the used motor oil will drip about a day.
Old Aug 25, 2009 | 08:56 PM
78bigbronco
Good ideas. So I guess using used motor oil isnt that unheard of. I kinda though my friend was crazy all these years since I never heard anyone else do it.
Someone suggested I used POR15. Never really heard of that before. Anyone use it? I need to do something... just looked underneath and there is already rust over many things, apparently lots of bolts/rivets were not painted as they are completely covered over with rust already. About a month and a half old and 2,200 miles and she is already rusting.
Any spots particular that need attention? I know on my 99 150 the bottoms of the doors are rusted badly, as well as the cab corners (1 has a 2-3" wide hole), and the bottom of the tailgate. The funny thing is where I scraped the paint off the door in a fender bender still appears to be bare metal years later, as well as about a hundred gouges in the bed through to bare metal have not seemed to rust. Guess the biggest thing is what is down at the bottom that gets the salt spray.
Old Aug 25, 2009 | 09:07 PM
big poppa's Avatar
big poppa
If you want to do it right, from the start and be done with it, POR-15 seem's like the right choice. I'll be doing this soon before the cold weather arrives, I,m keeping my truck too. Check out their link above in the sponsor section and read what it does, i,m sold. Good luck.
Old Aug 25, 2009 | 09:16 PM
Headviking's Avatar
Headviking
What do you guys use to spray used motor oil with? I thought of one of those pump garden sprayer. Would this work?
Old Aug 25, 2009 | 09:31 PM
78bigbronco
I've never seen it done but my buddy says he uses old spray bottles like for windex. Seems like that would be a lot of work I think one of those pump up garden sprayers would be easier but you'd pretty much have to get one just for that, dont think I want to be spraying the garden after oils been in there lol.
And I'll look further into the POR-15 unless someone wants to suggest something better.
Old Aug 25, 2009 | 09:38 PM
Mustang6147's Avatar
Mustang6147
I like the Rustoleum silver can... I brush it on, then touch up tight spots with a spray can. Brushing it tends to last longer.
There is a product called "penitrol" it is made by Flood co... Ace hardware has it, and it also is good. The only problenm with penitrol, or oild spray, is it drips on the drive, and in the garage. What a mess it is.
Old Aug 25, 2009 | 10:39 PM
jlmotox's Avatar
jlmotox
I want to do my inner fenders behind the wheels...anyone have any suggestions? I was thinking of using bedliner in a can... I want something that will stay black for a while, and be easy to keep clean...
Old Aug 25, 2009 | 11:02 PM
big poppa's Avatar
big poppa
Sorry fellas, thats Rust-Bullet above in our sponsor section, not POR-15, my mistake. I just noticed at the very botton of all my rear fender wells got spots starting, darn Ford factory mud flaps, they we're lose and they wore some of the factory paint off, shees. Looks like i,m getting it sooner now.
Old Aug 25, 2009 | 11:15 PM
xrmarty's Avatar
xrmarty
buddy of mine used this on his motorhome. Stuff work GREAT!
http://solutions.3m.com/wps/portal/3...gl95XCS2Q1PZbl
Old Aug 25, 2009 | 11:20 PM
xrmarty's Avatar
xrmarty
Heard this stuff is really good also:
http://multimedia.3m.com/mws/mediawe...6EVs6E666666--
Old Aug 26, 2009 | 04:40 AM
racinghoss's Avatar
racinghoss
I had the dealership spray undercoating under my truck when I bought it. They also did the bedliner, so I assume the stuff is the same. It has held up pretty good so far. I bought the truck in 2005 and no problems yet. I will likely do the same thing with my next truck.
Old Aug 26, 2009 | 01:04 PM
78bigbronco
I'll check out some of the others mentioned above. One other thing, do mudlfaps really help? I've heard both sides here, some say they trap moisture around where they mount to the wheel well. I definately want some extra protection and I checked out the duraflaps that folks here reccomend, but looks like its gonna be about $170 just for plain rubber ones, that seems way steep to me for a couple hunks of rubber. Plus I dont really like the look of flaps especially the larger ones. But I want to prolong this trucks life any way I can...
