Overheating Problem
Old Aug 19, 2009 | 05:20 PM
riverbottom's Avatar
riverbottom
Overheating Problem
I have a 97 F-150 4x4,4.6liter V8. The problem...temp gauge goes to hot and fail safe cooling light comes on but after about a minute the gauge returns to normal and the light goes out. This only happens on a cold start. My pressure cap does pop and I do lose a little coolant from the resevoir bottle. I have replaced the thermostat, water pump, radiator hoses, all temp sensors and have flushed the radiator. Any Ideas? HELP!
Old Aug 19, 2009 | 05:25 PM
FordxFour's Avatar
FordxFour
Have you replaced the cap?
Old Aug 19, 2009 | 05:27 PM
cbradford's Avatar
cbradford
Maybe you want to try the 4.6 Forum or F150 Forum
Old Aug 19, 2009 | 05:32 PM
riverbottom
I have replaced the cap.
Old Aug 19, 2009 | 08:06 PM
UrbanXX's Avatar
UrbanXX
Check for a faulty connection at the tempature sending unit and/or the sending unit.
Old Aug 19, 2009 | 09:14 PM
riverbottom
I have replaced the temp sending unit and the cyclinder head temp sensor. I will check my connections again. Thanks
Old Aug 19, 2009 | 09:25 PM
UrbanXX's Avatar
UrbanXX
Well lets do a more in deph check.
When the tempature gauge reads high, open the hood (without touching anything) and do be cautious, look for a colasped hose.
No colasped hose, then run a pressure check on the cooling system with thermostat REMOVED and the engine COLD. I take it from your post this engine reads hot shortly after cranking it.
If it is losing pressure with the thermostat removed and engine cold, this COULD indicate a bad headgasket putting compression into the cooling system. As the engine heats up of course metal expands under heat and it would seal the headgasket.
I am assuming when the engine resgisters hot the engine is actually hot and it is not a faulty gauge. One can usually tell from the heat of the of the engine if it is hot enough for the gauge to peg-out.
Old Aug 20, 2009 | 07:21 AM
cbradford's Avatar
cbradford
You can also find someone to test for exhaust gasses in your cooling system this is sure why to test for a head gasket problem or cracked head. Here is a link:
http://www.arrowheadradiator.com/hea..._leak_test.htm
