Rebuild or replace?
Old Dec 31, 1969 | 06:00 PM
Guest
Guest
Posts: n/a
Rebuild or replace?
Old Jan 17, 2003 | 07:50 AM
kuli48's Avatar
kuli48
Rebuild or replace?
I have a 84 f150 with a 351. It seems to run fine. It has a fuel leak from two places the front pump diaphragm, and the front of the fuel transfer tube. I'm not sure I'm up to a complete overhaul job. Can you, or is it wise to just do the two areas that are leaking? Is there an easier way to fix my leaks other than a complete over haul? If I need to replace the carb what with and where is the best place to get it? The Numbers on the carb are E4TE ARA I think a Hollie 4180C.
Thanks
Mike Kulisky
