cleveland pulleys
Old 08-14-2009, 10:56 PM
leroy78's Avatar
leroy78
leroy78 is offline
cleveland pulleys
My truck originally came with a 400m which was later swapped to a 351c, 2 years ago i swapped in a 351w because the cleve was getting tired, the 351w came out of a grand marquis and has the aluminum brackets for the ac ps and alt, The cleve has been rebuilt and is going back in but what i need to know is if i can run the bracket system off of the windsor so i can have a serp belt system instead of the v belts.
Old 08-15-2009, 12:44 AM
johnboy427's Avatar
johnboy427
johnboy427 is offline
Don't know on every thing. When I did my swap I used a power steering bracket off a W, but the Alt bracket didn't work. The AC stuff off the 400 worked fine. None of the belts are the same and a 400 and 351W pulley wouldn't fit my Cleveland but I am running an aftermarket dampner so they might fit the stock ones. I would just try it that will tell you more than I can, but the Cleveland's lower deck will most likely be a problem.
-Johnboy
