well i scanned my truck again, and now i have the actual codes to post, i dont really understand the description the computer give me, so i figured someone else would know. I do know that one is an O2 sensor, and the other has something to do with the EGR valve.
That's the rear sensor behind the cat. The code is telling you the heater circuit isn't working so it could be as simple as a blown fuse or wiring problem.. or the sensor could be bad.
are you sure about the the O2 sensor, because my truck doesnt have one after the cat, it has 2 in the exhaust manifold and one right in front of the cat and that is all it has.
