Any VW mechs here?
VW mech here
I used to work on the old VWs for years. VW trannys can be tricky. Is your tranny one with CV joints or the older stiff axel type? It looks like the older type (better for off road). Where is the leak specifically coming from? There are gaskets behind each axel base plate and there is a gasket behind the gearshift housing and there is a gasket between that and the gear carrier housing. You could make those gaskets given a large enough piece of paper gasket material. There is also the seal around the clutch shaft behind the motor. Parts are getting much harder to get for the older stuff in Canada. Yoy may have to order from wolfsburg west in the US. I don't know if Worldpac will have anything. Since Bow Wow closed it's doors, easy access to good older VW parts is difficult.
Mutant
'96 F350 4x4 crew:Headmann, Jet,BBk, AirRaid, K&N,Flowmaster, American Racing.
Mutant
