Leveling Kit?
Old Jul 18, 2009 | 08:38 AM
hanlinhound's Avatar
hanlinhound
Leveling Kit?
I am looking for a leveling kit for my 03 F-250 4x4. I am wanting a leveling kit that will also bring the back up a couple inches also. Any ideas? Can I use F350 blocks in the rear? I appriciate any help.
Ryan
Old Jul 18, 2009 | 09:03 AM
BGMSPD's Avatar
BGMSPD
Ryan,
You can go get a leveling kit of your choice, i have a pro comp kit that came with new front leafs and shocks all around. I've had no problems and like the kit. you can also go get the rear blocks for a 350 which will give you an extra 2" over your existing rear blocks. i have pics of my truck in my gallery with the leveling kit installed. it turned out perfect and sits level and the ride quality is no worse than it was stock
Old Jul 18, 2009 | 12:39 PM
hanlinhound
Thanks! How much was your pro comp leving kit? Also, you suggested putting the F350 blocks over my existing blocks? Is that safe? That seems like a lot of stacking....
Ryan
Old Jul 18, 2009 | 06:04 PM
Maxium4x4's Avatar
Maxium4x4
You replace your original 2" blocks with the F-350 blocks.
Old Jul 19, 2009 | 09:53 PM
BGMSPD's Avatar
BGMSPD
yea definitely no stacking, swap out the blocks. as far as the kit i don't quite remember because it was a couple of years ago but there are numerous sponsors on here that will give you competitive prices. Then there is install depending on your skill level and i believe i had an alignment done also just to be on the safe side.
