Towing a vehical
if there are no hills there, you may tow safelly. But try to get dolly ore 2 axe trailer with built-in brakes. I used to tow many vehicles and be sure you can tow up to 2500 kg with ranger, but hitch load must be about 200 kg. I used to tow so heavy things with my aerostar 3.0 that before hill I had to stop and let engine cool to 50-60 dgr C. At top point I had 98-105 dgr C and steam clouds from under hood. I had 1600 kg inside and about 2000 kg in trailer. It is funny but in crazy 90-s we used to haul chocolate from Germany with Aerostar. ))) then we purchaised two VolvoF10 trucks with draw bar 10 ton trailers. So we hauled 20-30000 kg. It was a good towing (and backing and parking with trailers) school for me.
Well make sure the Rangers & towed vehicles tires that are down, are aired up good & maybe put a bug screen over the Rangers front end to keep the bugs out of the tranny oil cooler & radiator fins, so you get max air flow through them & have a good safe tow.
Will be interesting to hear how it goes.
OK, well it was a long tug by most standards, so you did good to change the fluids & take it slow & not push things along the way, as the Ranger was likely close to, or maybe over it's max weight some.
Can you drop the tow dolly off, or are you gonna have to bring it back????
If you have to return it, will it fit in the bed, so you can just haul it, might make for a nicer transport that way.
Mdc9966
21
06-14-2015 11:28 PM
DPDISXR4Ti
22
12-20-2012 08:57 AM
greenmachine76
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
05-06-2011 04:15 PM
speedsauto
03-12-2003 03:52 PM
