Engine problems?
Old Jul 2, 2009 | 10:11 PM
Plums72's Avatar
Plums72
Angry Engine problems?
Ok, so heres the deal, i have a 1986 F150 4X2. 5.0 EFI.
put the motor that is in it, in after my original one blew a head gasket(it needed a rebuild anyway, but im not gonna do it for a while)...anyways, im positive the motor is in good shape, it runs too strong to not be. The problem i have is that it acts like its got a huge cam in it??? i crank it up, and it lopes like a dragster...<<WTF???. when you first crank it, if you dont tap the gas, it will die within a minute. give it gas and it just goes to a choppy idle, get in put it in gear, and it will putter off, give it gas, it dies down, give it a SMIDGE more gas.... it roars to life like monster...again<<<WTF. after you get going it runs ok, until you find a speed your comfortable with....usually the sped limit... then it starts to bog down, it will get so choppy at 45, i can watch my front end pop up and down?. the only time it doesnt do anything retarded is when its ***** to the wall pedal to the floor...one more time<<<WTF???.
Ive cleaned the butterfly and everything that it connects to, the only thing i havent cleaned up top really is the plentum itself...
oh yeah, and my vacuum solenoid makes a lot of clicking sounds when you give it gas and let the gas goo???
ive been battling with this for about 5 months now, ANY help would be appreciated guys...
TIA.
Plums
Old Jul 2, 2009 | 10:31 PM
Franklin2's Avatar
Franklin2
What engine did you put in it? Some 302's have a 351w firing order and some have the regular 302 firing order. This is determined by what cam is installed in the engine. Moving the plug wires around will fix it if that is the problem.
Old Jul 2, 2009 | 10:35 PM
Plums72's Avatar
Plums72
came out of an 86 f150...
Old Jul 6, 2009 | 10:48 PM
Plums72's Avatar
Plums72
*Bump*
come on guys, i really need some help with this one....
Old Jul 6, 2009 | 10:59 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Did you do a computer diagnostic?
First thing I'd check would be the codes.
Old Jul 6, 2009 | 11:17 PM
Plums72's Avatar
Plums72
how much does Ford charge to do a diagnostic?
Old Jul 7, 2009 | 01:55 PM
81-F-150-Explorer
You would have to ask them.
Some dealer's won't do computer diagnostics on something that old anymore though.
You can buy a simple Ford OBD-1 code reader from a autoparts store for around $30.
Old Jul 7, 2009 | 10:29 PM
Plums72's Avatar
Plums72
thanks man. i appreciate it
kaukasion
18
Aug 17, 2012 07:42 PM
dwrestle
13
Nov 17, 2011 09:12 AM
blackmajikf100
Dec 12, 2010 09:02 PM
BigBlue04
Oct 20, 2009 07:55 AM
automike25
Modular V10 (6.8l)
21
Jun 5, 2007 04:19 PM
