abs problem
Old Jun 15, 2009 | 09:30 PM
kain81's Avatar
kain81
abs problem
My abs light is flashing 10 times. Had it checked out once before at firestone but they said they didnt know and should take to to the dealer. It just started flashing tonight, before it just stayed on. Dont really want to take it to the dealer right away if I can fix it myself or at least get an idea of whats the matter . The truck stops fine and the brake fluid is almost full.The brakes pads are fine and the brake pedal feels a good.
They didnt get any codes at firestone , but they refered me to the dealer though. I do have a left turn signal that keeps going out. That could have absolutly nothing to do with this.
Thanx in advance for the help
Old Jun 15, 2009 | 09:34 PM
Talyn's Avatar
Talyn
Check the sensor on the rear diff.
It might be bad, if its not good, or has metal on it, it will make the light turn on.
Old Jun 15, 2009 | 09:38 PM
kain81's Avatar
kain81
Ill do that asap and check back here.Thanks for the help.
Old Jun 15, 2009 | 09:47 PM
Talyn's Avatar
Talyn
its a pretty cheep part to replace.
there is a chance it will break when you pull it out also.
Old Jun 15, 2009 | 10:13 PM
tbone heller's Avatar
tbone heller
x2 , replace rear sensor.
