Code reading questions
Old Jun 5, 2009 | 12:29 AM
300k f350's Avatar
300k f350
Thought I had a problem with a new cam sensor... Truck is still stalling occationally after replacing cam sensor... codes:
p0603 power train control
p0340 cam shaft sensor
p1501 speed sensor
p1283 injector pressure regulator circuit
p1211 injector above /below desire
Wondering what the injector codes might mean?
Old Jun 5, 2009 | 06:06 AM
megawatt00's Avatar
megawatt00
Welcome to FTE
Do you have any mods on the truck? Chip or tuner, exhaust etc? Where did you get your CPS from? Some of the new ones have been known to be bad, or cause other issues especially the ones from the big parts stores (AutoZone etc).
megawatt00's Avatar
megawatt00
Welcome to FTE
Old Jun 5, 2009 | 10:33 AM
300k f350's Avatar
300k f350
The truck is completely stock. I got the CPS from Kragen.
Old Jun 5, 2009 | 10:55 AM
PaysonPSD's Avatar
PaysonPSD
Welcome to .
Did you get the codes cleared? If so, was it before or after CPS replacement?
Old Jun 5, 2009 | 11:57 AM
clintbonnie's Avatar
clintbonnie
Did you buy the truck new..? Some of the codes indicate there is a tuner/programmer installed..
Old Jun 6, 2009 | 09:23 PM
300k f350's Avatar
300k f350
Bought truck 3 years ago with 197,000 miles. I have replaced the cam sensor twice and and 15 months ago the wiring harness shorted on the valve cover from a wear point. Three hours, $375.00 later, a couple strips of electrical tape and two zip ties, Ford garage had it all fixed. While it was in there they did a recall on the cam sensor. The new up graded sensor was installed. Last week I took it in to get replaced again... I purchaced a $200 code reader from Kragen... The truck is still stalling occationally...
