So, I'm driving down the road in my '09 STX and I reach down to turn the defroster on and accidentally hit both, the power button and the defroster button. I notice that the defroster didn't come on, so I hit the defroster button again and I get three temp displays, one in each corner of the little window where the radio displays are at. There's also a small display that represents fan speed.
So, while I'm at the redlight I'm messing with the buttons again. I learn that if you hit both the power and defroster at the same time, then hit the defroster again you'll get the three temp displays and the fans speed. If you hit the power button then the displays will go away but the defroster stays on. Please note that the temp displays all show "0", not the actual temperature inside or outside.
My question is....does anyone know how to make the temp displays actually work? It would be nice if we could see the inside and outside temperature as we're driving.
