MA May BS thread-Let's get ready to rumble
#872
Shaun, my condolences on the demise of your desktop.
I'm trying to figure out how to assemble such a machine with two water-cooled video cards.
What I am concerned with is having sufficient space between the two video cards in an SLI setup (Bridged together) to facilitate connecting the lower card's water lines.
#873
Thanks Dave but it has been doa for awhile. The os crashed and then it would not let me install any os on it. I have even tried replacing the hard drives but it wont install anything. So I will look at the upgrades I cant afford right now and get them when I can.
It shouldnt be to hard to do Dave. The only trouble you may run intop is installing the water system for the cards. you might want to try newegg.com for some ideas on the components to get.
#874
Good evening everyone...
Morning Shaun..
Just stopping in for a little while to see what is going on..
I am in the middle of doing some laundry and cleaning my room..
Morning Shaun..
#880
The weekend was good Don. There was no bash. And I did not score any new toys. I did have to buy a 42.99 dollar torx bit sunday to take the seat belt buckle bolt out. I had to buy the whole set to get the t50 that I needed. I also had to use a 1/2" impact gun with it to get the bolt out because of the corrosion on it.
#881
Well at least you were productive and finally got it out so you can get things rolling now..
#882
Yeah it was quite productive Don. Also managed to trace out the wiring in the cab of it. had about 8 different wires to trace. I unhooked all but one of them because I am still tracing it. It went under the ambo so I have to crawl around in the dirt to find it.
