$60 flasher required ????
I have to admit, I'm a bit stumped on this one.
I was given a utility trailer as payment for a snowmobile. It is in nice shape except for some of the lights were broken. So, I figured since I have connections (no pun intended) in the class 8 truck parts business I'd equip the trailer with all LED lights. I bought Truck Lite LED marker and oval taillamps to replace anything that was broken. Once I had everything swapped out, I hooked up the cord to my truck to test. Everything works except the stop & turn function of the tail lamps. I checked and triple checked the wiring, made sure grounds were grounded, made sure there was 12v power from the stop/turn wire of the harness. Still nothing. I bench tested the LED tails and they function perfectly. Why don't they work in thr trailer? I contacted Truck Lite and they advised for the Fords there is a special low-amp flasher required (#92783) because the LED draw so little amps the truck does not "see" that the lamps are there?
Has anyone else run into this before?
Thanks
E.
Thanks
E.
Unfortunately, it is true. I had a similar problem. I installed LED signal/brake bulbs in my 2002 Supercrew. What would happen to me was that the flashers would blink fast, like when a bulb is burnt. The issue was that the amperage draw was to little for the flasher to sense it, thinking the bulb was burnt. Replaced the flasher with the low-amp one. All Fixed. Hope it helps. I bought the flasher through Ford - a lot cheaper than $60.00.
