Hot start problems
#46
The IAT goes in the air filter box on mass air trucks. If you have a speed density truck, I don't believe you have this. I think it was only on mass air trucks. Seeing as how you have a MAP, your truck is speed density. I believe all the 460 trucks were speed density. Where is the IAT located on the 460?
#48
I had a similar hot start condition that a few shops and 2 Ford dealers could not figure out. An SVT mechanic even looked at it. It turned out to be the injectors. They would leak fuel into the engine and flood it out when the engine was shut off. I just replaced all of them.
The problem my F150 had was it would start fine when cold, but after being driven it would be very hard to start unless you started it back up within a few minutes. It would normally have to sit for a few hours or longer before it would start normally.
#50
drop a penny in the tube and hand tighten the tube back on to the EGR valve.
This so you do not mess up the tube to valve mating surfaces.
JasonVanByrd
10-26-2015 09:31 AM
usuallybowtie
06-04-2014 11:39 PM
