any ideals on lifting a 2wd cheaply
Old 04-29-2009, 08:58 PM
bubbasinafordf150's Avatar
bubbasinafordf150
bubbasinafordf150 is offline
anyone got any ideals on how to lift a half ton 2wd 73-79 dentside with out using springs spacers or 700 to 1000 dollar i beams and springs
Old 04-29-2009, 09:00 PM
Holiver31's Avatar
Holiver31
Holiver31 is offline
Its a 2wd. Why? And ive heard talk of possibly flipping the I-beams for a little height. But why?
Old 04-29-2009, 09:10 PM
bubbasinafordf150
id like the look of a 4 wheel drive and i want to clear at least 33s
Old 04-29-2009, 09:27 PM
Jermafenser's Avatar
Jermafenser
Jermafenser is offline
33"? On a 2WD? Are you compensating for something?
Old 04-29-2009, 09:47 PM
Holiver31's Avatar
Holiver31
if you dont have to much invested in your truck now, i would personally sell the thing and get a 4wd
Old 04-29-2009, 10:13 PM
bubbasinafordf150
33 for cleareance and no im not trying to compensate for anythingm i was considering 31s but its more common to find 33s. and i cant get ride of the truck ive had it for 4 years and its now part of the family
Old 04-30-2009, 02:14 AM
fmc400's Avatar
fmc400
fmc400 is offline
MSEE
You asked, "Can I do _______ cheaply on a 30 year old pickup truck?"
The answer:
No.
Wise words for all: if you're strapped for cash, find a new hobby. I know too many people that sacrifice car insurance for a billet grille!
Old 04-30-2009, 02:35 AM
bubbasinafordf150
i dont mean sacraficing insurance for a billet grill, what i mean is a way to lift a 73-79 2wd for under 200 bucks with out using coil spring spacers
Old 04-30-2009, 02:37 AM
Skip1970's Avatar
Skip1970
Skip1970 is offline
the cheapest way to lift it would be to overinflate the tires with air.
Old 04-30-2009, 07:31 AM
Holiver31's Avatar
Holiver31
For under 200? Not possible.
Old 04-30-2009, 10:12 AM
jsutton's Avatar
jsutton
jsutton is offline
What about a Body lift? It would be cheaper than the suspension lift. I know a lot of people don't care for body lifts, but since it's a two wheel drive anyway you are going to be doing any serious wheeling to shear off the longer bolts. Just my .02
http://roughcountry.com/body_lift_kits-ford.html
EDIT: After posting that link I see it says it won't fit a 2wd with the steering gear box behind the front axle. But anyway maybe someone makes one for a 2wd.
If not the maybe you could modify the steering column to gear box connection with some shaft and steering universal joints.
Old 04-30-2009, 11:10 AM
Holiver31's Avatar
Holiver31
Ford Body Lift Kits
Body lifts use spacer(blocks) which he doesnt want to use.
Old 04-30-2009, 11:15 AM
bubbasinafordf150
i was thinking body lift but the steering issue is what gets me. what about taking the steering knuckle from a 4wd gear box and putting it in place of the rag joint. body spacers are ok. i just dont want to add any spring spacers,
Old 04-30-2009, 11:20 AM
Holiver31's Avatar
Holiver31
I thought you didnt want to use blocks?
Old 04-30-2009, 11:31 AM
bubbasinafordf150
not in the suspension. i just got done rebuilding the entire suspension on the truck about 1 month ago. i figured if i put 460 springs under my 300 inline 6 it would raise the front end up a little but it didnt do it
Quick Reply: any ideals on lifting a 2wd cheaply
