Help! E4OD code
Old Mar 15, 2009 | 07:05 PM
jeffsk7's Avatar
jeffsk7
Help! E4OD code
My overdrive light falshed toaday but then stopped. The tranny was rebuilt with HD torque converter and overdrive and is also equipped with an tranny cooler and a knew MLPS only 6000 miles on it. The o/d flashed happened twice. The second time it happened was when I put it in reverse the tranny pooped into gear a littler harder than normal. I then turned the truck off and back on and there was no flashing. Let me know what you guys think. Also how do i test to see what code is comming up.
1993 f250 ext 4x4 125000 miles 7.3 idi
