Jessicas tale, the story of a dead truck
#196
#197
yes it is gone...no prob on the wheels and tires, when i said 31 i was going off memory so 32s will fill your wheel wells better on the extra cab....yeah it fit ok, i droped it in before i started painting. really the big factor for this thing is the cup holders, i dont need a ton of them but not having any is getting old.
#198
Plus the little storage compartment in those center console things is cool too. It should work out well for you.
#199
#202
so i put it back together and this is what turned out:
and in the truck:
but it needs to come back out for a second coat of paint.
also what do you all think i should put in it? power inverter, DVD player, 12V power plug...
the PS2 needs to come out anyways it wont play most DVDs so i also need something to go where it is too...
and in the truck:
#204
#206
and i am working on getting on board air, i have the tank and air switch and gauges all hooked up and the air line run the the motor, i am using an York AC pump for the compressor...but the one i have doesnt line up to the crank or water pump so i am going to try one other compressor, and if that doesnt work i might try a different mount. my truck came with AC and this is the same mount so i am not sure what to do, but i will get it to work...
