superchip programer
Old Feb 18, 2009 | 01:26 PM
wingerpaul's Avatar
wingerpaul
superchip programer
1705 super chip, I have installed the towing program in my 2002 7.3 it seems to be alot more reponsive however the shifting is firm but a little rougher than before just what does this program do the the stock program and the engine? I will be hauling a fifth wheel and I know to not push it uphill I will monitor the trans temp untill I can get boost and exhaust gages.I only have a little bit of the blue ridge to go though and they didn't even cause me to shift out of overdrive but a couple of times. <!-- / message --><!-- BEGIN TEMPLATE: ad_showthread_firstpost_sig --><!-- END TEMPLATE: ad_showthread_firstpost_sig -->
<!-- controls -->
Old Feb 18, 2009 | 03:08 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
I ran the Superchip for 4 years without gauges. The tow tune will not get you in trouble, at least it didn't hurt me towing heavy loads in the mountains. I did put gauges in before I got the DP-TUNER and seen I could not get the EGT to 1200* climbing steep grades.
It would be a good idea to get a good turbo back 4" exhaust system, or at least a muffler delete. A good intake, 6637 is very well liked around here.
I feel I must say, drop the Superchip and get a DP-TUNER. I could not believe the difference between the two.
Old Feb 18, 2009 | 03:09 PM
big poppa's Avatar
big poppa
^^What Rick said, i had one also.
Old Feb 18, 2009 | 03:20 PM
wingerpaul's Avatar
wingerpaul
Thanks for the replies This programer was given to me and I have no other mods. I will be leaving Fla and going home to Murphy NC Sat. there are no large mountains and I will take it easy so I believe I will be ok with out any Guages I will keep an eye on the tranny temp.
Old Feb 18, 2009 | 03:27 PM
miller_feed
I wouldn't worry about it either, you will be good. Have a safe trip.
02GrayPowerStroke's Avatar
02GrayPowerStroke
Do not rely on you stock tranny temp, its for show. I installed an Autometer set of gauges and I can tell you the stock tranny temp gauge is a POS.
Old Feb 18, 2009 | 03:30 PM
rbaker6336's Avatar
rbaker6336
where in murphy are you located? My son lives in marble and I sometimes live in blairsville
right now stuck in Fla
Old Feb 18, 2009 | 03:59 PM
CSIPSD's Avatar
CSIPSD
Keep the RPM's up, its against your first instinct to do this but 2400-2800 is where you want to be when pulling ANY HILL when you do not have an EGT gauge...
I have a melted piston on my desk from my early 99 (smaller injectors) and a superchips tuner set on "tow performance" and using 1100* Red line post turbo pyro...
Cost me about 3k to fix back then. Get an EGT gauge now, or run it stock...
Old Feb 18, 2009 | 08:08 PM
wingerpaul's Avatar
wingerpaul
I have a trophy & Jewelry repair Shop on 64/74 west side of town.
Old Feb 18, 2009 | 08:23 PM
rbaker6336's Avatar
rbaker6336
Think I have saw something out there like that but can't exactly place it
