Modular V10 (6.8l)
Who has the most miles on their V10??
  #106
Old 02-19-2011, 07:26 PM
BBoy's Avatar
BBoy
BBoy is offline
2008 with 119000 km(74375miles) runs fantastic, just got it 2 months ago so unknown maintenence, needs two manifold studs and probably a all round fluid change.
  #107
Old 02-19-2011, 08:01 PM
Csticks's Avatar
Csticks
Csticks is offline
I got 97000 on my 2003 Ford. Running strong!
  #108
Old 02-19-2011, 09:06 PM
super 6.8's Avatar
super 6.8
super 6.8 is offline
Just turned 40K miles on my 2007. Man how the time flies.
  #109
Old 02-19-2011, 09:49 PM
bdivine32's Avatar
bdivine32
bdivine32 is offline
Talking Millage
My 99 F350 v10 has 118k. Runs awsome! I just need to change the Plugs with new E3 Diamond fires.
  #110
Old 02-20-2011, 06:47 AM
SKI-V10's Avatar
SKI-V10
SKI-V10 is offline
Before you change those plugs you may want to read Sad V10 Owner thread. I hope the heat range of those plugs are exactly the same as Motorcraft. This motor seems to like stock plugs.
  #111
Old 02-20-2011, 12:08 PM
BigPigDaddy's Avatar
BigPigDaddy
BigPigDaddy is offline
STOCK PLUGS ONLY!!!
My dad, like many V10 owners, found out the hard way that Motorcraft plugs are the only thing to use if you want optimal performance. Do a thread search and you will find many others who have been down that road.
  #112
Old 02-20-2011, 02:14 PM
andrewzx92000's Avatar
andrewzx92000
andrewzx92000 is offline
200,000 v10 van E350 One alternator, 2 coils, lots of boots and plugs to deal with miss.
Great vehicle 14.3 mpg on the interstate at 80 mph 3.73 gearing 15 passenger srw.
Runs as good as new.
Andrew
  #113
Old 02-20-2011, 08:45 PM
ToaDisco's Avatar
ToaDisco
ToaDisco is offline
I'm got 186,600 on my 99'. It's still running strong and don't see any signs of it slowing down thankfully.
  #114
Old 02-21-2011, 12:14 AM
BigLouEx's Avatar
BigLouEx
BigLouEx is offline
My 2000 f250 had 190000 on it when I totaled it (360 with half twist). Actually started up the motor so the tow tuck could steer on to the flatbed. Bullet Proof! Have 2000 Ex with v10 now.
  #115
Old 02-21-2011, 04:55 PM
Jr.Ranger-04's Avatar
Jr.Ranger-04
Jr.Ranger-04 is offline
Originally Posted by BigPigDaddy
STOCK PLUGS ONLY!!!
Friend just bought a 99 f-250 with 96K is there any issues with changing the plugs on these motors that a person should know about???
  #116
Old 02-21-2011, 10:27 PM
Old Time RV'er's Avatar
Old Time RV'er
Old Time RV'er is offline
need to check
there is LOTS and LOTS of info on this site that you need to look up before you decide to change the plugs unless you are very good and understand the problems. It could be easy, it could be a very big problem for you. and lots of $ you need the right rpocedure the right plugs the right never seaze the right toqure.... depending on who you want to listen to and who's experience you want to pay attention to... it is your decission in the end. but you better listen to esperience or you will be sucking wing and trying to figure out what to do with plugs that blow out of the heads taking the threads with them. I sure can't summerize it, just start poking around and spend some time reading then make up your own mind and live with your decission..... beleive me there are a lot of issues where. I know what I do and what has worked for me so far, but I could have a problem tomorrow, so I sure ain't gonna tell you what to do... make up your own mind.
  #117
Old 02-22-2011, 09:26 PM
Jr.Ranger-04
Thanx for the info, I have a 04 5.4 dealer broke 7 of 8 at 60K just wasn't sure on the v-10 will send friend to dealer for that, also could u tell me what wieght oil and how much and which filter for this rig he has no owners man. in it??? Thanx again..
  #118
Old 02-23-2011, 07:07 PM
Old Time RV'er
The book says 6 qrts, the dealer will put in 6, but when yu do, you are a quart low. I always put 7, and that brings up to the full mark without being overful. everybody calims the 2-20 is the best oil. I tried synthitic, but ended up burining off 2 qrts by 5,000 mi.... that about $14 of oil, so just went back to good Castrol and 3,000 mile changes.
  #119
Old 02-23-2011, 11:10 PM
Jr.Ranger-04
Did u mean 5/20 syn blend, that is what I use in my 5.4????
  #120
Old 02-24-2011, 10:46 AM
ol'yeller's Avatar
ol'yeller
ol'yeller is offline
My '99 F250 SD,SCAB, 2WD V10 will hit 100K by the end of the month. I bought it used 8 years ago with only 33K on it. I only use 5W20 oil, changed religiously every 3K miles. I have had the trans fluid changed every 30K as I tow my 8,000# travel trailer with it. I have had some repairs, the most expensive being the infamous broken exhaust studs. I did change the plugs at 75K. I had the rearend regeared to 4:30s from the original 3:73s and added an Eaton limited slip. It really woke up the V10, especially when towing. At the same time, I had all the hoses and belt changed and all the fluids drained and flushed and added a tranny temp gauge. I also needed to replace the pitman arm at that time. The shop cleaned the MAF and the injectors and replaced the O2 sensors. I have the ABS fluid changed every other year. The only other expenses were new ball joints, a couple of brake jobs, a battery, tires, a bad COP, and I will soon need to replace my fan clutch. I don't view any of this as shortcomings of the V10. The truck is mostly retired from daily chores (as I have too) and will mainly be used to tow our RV trailer for the forseeable future. I love my V10.
Quick Reply: Who has the most miles on their V10??
