reducer question
Old Feb 9, 2009 | 06:18 PM
tpolley's Avatar
tpolley
reducer question
where can i buy a reducer or adapter to go from 2-1/2 to 3-3/4inch and another reducer or adapter to go from 3-3/4 to 5 inch.
here's what i've got. a '92 ford f-250 with a 7.3l na diesel. i'm wanting to install some 5 inch stacks true dual.
my plan is to cut the exhaust off as it comes down the back of the engine.
there i will install a 2-1/5 inch to 3-3/4 adapter.
from that i will run 3-3/4 inch flex pipe to the outside of the frame at the front of the bed and install a 3-3/4 90 degree elbow to to 3-3/4 to 5 inch addapter into a pre-made flange, or mounting assembly (haven't got that far in the design stage yet) that will exit thru the floor of the bed where i will install the stack.
i will do this on both sides.
Old Feb 14, 2009 | 10:31 PM
351M's Avatar
351M
Anyplace that sells Walker exhaust should have them. Or...
Walker Exhaust Systems And Parts - Solutions From the Industry Leader
Old Feb 19, 2009 | 03:47 PM
ghunt's Avatar
ghunt
Where do you plan to get 3 3/4" flex pipe?
Also, are you sure about running the pipe UNDER the frame, it'll be very visible there and prone to damage.
Kinda sounds like you're doing it the hard way.
