Limited Slip Differential
Old 02-06-2009, 10:51 AM
Holiver31's Avatar
Holiver31
Holiver31 is offline
Does anyone know of a Limited Slip differntial i can use in a 77 F-150 2wd?
Old 02-06-2009, 12:36 PM
garypettengill's Avatar
garypettengill
garypettengill is offline
There are a number of aftermarket manufacturers of limited slip/posi-traction units for the Ford 9" rear end in you truck. Ford also made a unit refered to as "Trac-Loc" for these trucks. Go to Jeff's Bronco Graveyard, Early Bronco Restoration Full Size Bronco Restoration Classic Ford Bronco Parts For Sale, you can get some ideas there.
Old 02-06-2009, 01:07 PM
slinger34's Avatar
slinger34
slinger34 is offline
If you want to go with a locker you could get a power trax locker. Every thing fits in the stock diff case. locks when on the gas and unlocks when coasting around turns. Friend had one in his ranger, worked great, did not handle to bad with it. Thinking about getting one for my F-150.
horsepuller
Offroad & 4x4
46
01-25-2014 09:08 PM
micguyver
1999 to 2016 Super Duty
11-11-2009 09:00 PM
GeneStoner
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
03-20-2003 09:00 PM
m
1997-2006 Expedition & Navigator
11-20-2002 07:32 PM
warmdye
07-28-2002 05:58 PM
Quick Reply: Limited Slip Differential
