330 interchangable with a 370?
Hi guys,
I have a 87' F60 with a bad 370 motor. I found a 74' F600 with a 330. Can I put the 330 in the 87'?
This would probably just be to get me through the winter ( I deliver coal)... I would either rebuild the 370 in my spare time or find the right diesel engine and trans to put in it over the summer...
Any thoughts?
Thanks,
Austin
Any thoughts?
Thanks,
Austin
I believe the 330 is an FE/FT engine while the 370 is related to the 429,460 engines so I doubt the trans would bolt up to the 330 engine if you are reusing your transmission. If you could get the engine/trans, you could probably make it work with some fab for motor mounts & little things like that.
I was aftaid of that, the 330 comes with a complete truck that is drivable... So the trans should be good, but not sure i want to modufy it because i dot think it will be in there for too long...
Would any 460 work? If I found a mid-80's f250 with a 460, there are plenty of those around...
Ok,
Serving suggestion: Limp along with the 330 motored truck while you rebuild you existing 370.
doersam56
17
09-23-2012 08:31 PM
jnehring
09-07-2007 12:53 PM
