4.2 oiling system
Old Jan 5, 2009 | 07:16 PM
Bricks88's Avatar
Bricks88
4.2 oiling system
Hi everyone. I have a fairly new (rebuilt) 13 k 97 4.2 with no oil reaching the lifters but 70 psi on a mecanical gauge in the oem idiot light location. This problem has also shown up and gone away last week twice.Now its back Im thinking the oil pump relief valve is sticking open,but is the oil preassure fitting before or after the relief valve? any help would be appreciated, Thanks
Old Jan 8, 2009 | 07:31 AM
bokker's Avatar
bokker
hi, just checked with the old casting and the relief valve is set into it as an interigal part. the casting is where the oil pump is fastened onto. with the oil pump removed i was able to move the pressure relief valve off its seat and check that is able to move freely under its spring pressure.
i am unable to remember where the take-off is for the oil gauge but if it comes off the oil pump then the pressure is made from the pump then up to the oil gallary to the pressure relief valve.
all a bit iffy but hope it helps. bokker.
Old Jan 9, 2009 | 03:39 AM
Bricks88's Avatar
Bricks88
Thank you, bokker It gives me something to think about today.Ill pull the pump tommorrow.
Old Jan 15, 2009 | 02:26 PM
bokker's Avatar
bokker
hi, did you have any luck. bokker.
hoppy
Jun 12, 2020 01:42 PM
s22297l
Jul 15, 2012 11:56 AM
WnterHwk
1997 - 2003 F150
Jun 12, 2012 02:19 PM
Justins68ford
Jul 23, 2011 06:36 PM
rideordie
1983 - 2012 Ranger & B-Series
Feb 2, 2011 01:52 PM
