front end sheet metal 1953 f-100
Old 12-28-2008, 10:34 AM
ssweekley's Avatar
ssweekley
ssweekley is offline
Cool front end sheet metal 1953 f-100
I am having a very difficult time getting the hood and front fenders allighed.
The hood and fenders are all original that I took off. Hood sticksout about 1/2" passed the fenders. Hood fits fine @ cowl 3/16".
What am I doing wrong??
Old 12-28-2008, 10:38 AM
55 f350's Avatar
55 f350
55 f350 is offline
walk away for awhile and the problem usually will present itself and be easy to fix .... otherwise get a BFH THEY USUALLY CAN FIX ANYTHING !!!!!!!
Old 12-28-2008, 11:00 AM
LEckart's Avatar
LEckart
LEckart is offline
Loosen all the bolts holding the fenders and adjust them forward to meet the hood by adjusting the two rods that go from the cowl to the fender/air dam. Kind of over simplified but take it slow and you should be able to attain good alignment. And WELCOME to FTE. go back into your profile and add where you are from in case someone is close and can help you more.
Old 12-28-2008, 11:10 AM
fking1's Avatar
fking1
fking1 is offline
Keep in mind that the hood/fender fits on the 53-56's leave alot to be desired. You will end up after, much adjusting, by compromising with an as good as possible fit.
