Adding cab lights
Old Dec 22, 2008 | 08:45 PM
crzycrazycarl's Avatar
crzycrazycarl
Adding cab lights
Has anyone added the roof cab lights to their truck. How hard is it to do? I would imagine you would have to drill 5 holes in the roof of your truck. Has anyone had a problems with them leaking?
Old Dec 22, 2008 | 09:03 PM
barebackjake's Avatar
barebackjake
i added mine, i made a template then layed them out on the roof, its easy to do just measure a few times to make sure and layout see how you like them, wiring is easy theres a cab light tail on the passanger side kick panel think it was a brown and ? wire tail i cant remember the other color but theres a plug on the end of it if i remember right
Old Dec 22, 2008 | 09:31 PM
MissIndependent's Avatar
MissIndependent
i did mine...it took 15 holes and the brown wire. i had to splice them, but it worked. and trust me, if i could figure it out on my own...you'll be fine
i got a pacer set off eBay for $50 and spent $2 on silicone seal so they wouldn't leak...although it poured rain a couple times before i got around to it anyways
Old Dec 22, 2008 | 09:35 PM
crzycrazycarl
Thanks for the help, have either of you had any leaking problems, the silicone idea is proabally what i will do
Old Dec 22, 2008 | 09:38 PM
MissIndependent
nope. mind you they've only been done since about july-ish though
Old Dec 22, 2008 | 09:39 PM
putz54143's Avatar
putz54143
make a template from another truck did it once years ago looked great
German Super Cab
Aug 25, 2011 08:15 PM
big yeller
Nov 13, 2007 03:18 PM
edub32
Mar 13, 2005 09:09 PM
95xltmud
Aftermarket Products
Nov 29, 2000 01:34 PM
