Check Engine?
Old Dec 19, 2008 | 12:54 AM
Prozon's Avatar
Prozon
Check Engine?
The truck is a 1988 F-350 with a 460 CI engine.
So I changed my engine a few months ago, and I removed the smog pump and EGR valve from the new engine.
Before the engine was pulled I had the check engine light on almost constantly. I pretty much just ignored it until I was forced to pull the engine. Most of the time it was an oil low thing because it had two dead cylinders and bad rings and burned quarts of oil in NO TIME. (It still ran when it was pulled.)
Anyways, with the new engine I still have a check engine light on. I assume it is something new, but it could be an old problem popping up again.
I ran a really confusing self-tester. Some "count-the-beeps" B.S.
I THINK my codes were;
  • EGR VALVE CONTROL SENOR
  • Throttle Position Sensor out of range
  • Power steering pressure sensor switch
I don't HAVE an EGR valve anymore, could its absense be causing this problem.
I have absolutely no idea how a throttle position sensor could be out of range. Could it have been installed wrong? What could I do to remedy this?
I didn't know my power steering had a sensor. The power steering pump leaked really bad on the old engine. ( I believe it was a hose and I believe I fixed the leak. ) I have not noticed any LACK of power steering but I did notice it was making a whining sound as if it was low on fluid.
If anyone can make sense of all this junk I just typed out and has any helpful idea's let me know!
I'm going to take my truck to someone who knows what they're doing with a tester. But until then, let me know what you guys think.
Thanks
Old Dec 19, 2008 | 08:01 AM
Conanski's Avatar
Conanski
Yes if the EGR valve is missing you'll get a code, that one should be obvious. The EGR system actually improves milage and there's no way to eliminate it without getting a code so your options are limited if you want to fix this. The TPS sensor is the type that measure mechanical movement so these things don't last forever, it's very possible it is malfunctioning and needs to be replaced. Many of these trucks have a pressure sensor in the power steering line, It's not a big deal if you don't have one or have it hooked up but you'll never get rid of the check engine light if it's not connected.
Old Dec 19, 2008 | 12:14 PM
Prozon's Avatar
Prozon
So there is no way to get rid of the codes without the EGR?
Old Dec 19, 2008 | 12:53 PM
pfogle's Avatar
pfogle
The only code here setting off the light is the EGR code. It's the only one that's emissions related. On the older (OBDI) computer it was set to only light the MIL on an emissions fault. Your engine is designed to run at optimum with the EGR installed, so reinstall it, and reset the codes. If the TPS code comes back replace the TPS.
Old Dec 19, 2008 | 12:54 PM
Conanski's Avatar
Conanski
The computer commands movement of the EGR valve via the EVR(EGR vacuum regulator), and measures the actual valve movement with the EVP(EGR valve position sensor), disabling either or both sets a code. If the complete EGR system is installed and operating correctly, but the EGR valve is blocked at the intake manifold, you won't get a code but the motor will be detonation prone because the computer adds more timing when it commands the EGR to open. This is why it's beneficial to keep this system. The only way you won't get a code and not make the motor ping is by spending $500 on a tuner to shut off the whole EGR routine inside the computer, but that's not terribly cost effective.
gregplus40
Sep 7, 2009 08:43 PM
Nightstalker
Bronco II
49
Oct 25, 2007 12:56 PM
bebad96
19
Jul 31, 2004 05:53 PM
bebad96
17
Jun 16, 2004 12:00 AM
jbblevin1
1983 - 2012 Ranger & B-Series
May 29, 2002 11:55 PM
