MAP sensor
Old Jul 11, 2010 | 04:01 AM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
If you are talking about the one that takes a 1" wrench with two black wires, That would be the Tachometer sensor.
-Enjoy
fh : )_~
Old Jul 11, 2010 | 04:05 AM
chicagodragon's Avatar
chicagodragon
ok, thanks a bunch.
Old Jul 11, 2010 | 09:20 AM
greywynd's Avatar
greywynd
The top one is the vacuum sensor that Dave S refers to in his earlier post. The bottom one is the tach sensor, if your tach isn't working right, it can be that sensor. It can also cause the tranny to act up, as it also relays info to the tranny control. (On E40D's.) If it's pooched, it's a dealer only item though.
Old Jul 11, 2010 | 09:48 AM
farmert's Avatar
farmert
The sensor in the last pic, by the oil fill, is the tach sensor. The one in the first pic is the baro sensor that Ford Trans Tech was talking about I think. Does you new truck have an autto tranny?
Old Jul 11, 2010 | 11:52 AM
starmilt's Avatar
starmilt
My map is in the console between the seats.
Old Jul 11, 2010 | 11:53 AM
Rick Wallace's Avatar
Rick Wallace
disregard ...............I hit the wrong button,somehow
Old Jul 11, 2010 | 01:17 PM
kenpobuck's Avatar
kenpobuck
That is the tach hook up for these engines. The loose and frayed insulation is the leading cause of failed or poor reading tachs.
Old Jul 11, 2010 | 01:18 PM
kenpobuck's Avatar
kenpobuck
Sorry didn't see that there was a second page lol.
Old Jul 11, 2010 | 01:21 PM
chicagodragon
ok, thanks. the wires are frayed, but the tach is working. still trying to figure out why this thing runs like poo
Old Jul 11, 2010 | 09:32 PM
LCAM-01XA's Avatar
LCAM-01XA
Originally Posted by chicagodragon
this is for low vacuum? i just got an idi as few hours ago and was wondering. there is a thread in the powerstroke section.
No, this is not the low-vacuum switch - what you have in this picture is the BARO sensor for the PCM, the low-vacuum switch looks kinda like a small tuna can, and lives on a large flat metal plate bolted to the passenger-side inner fender several inches behind the battery.
can anybody tell me what this sensor is? it was loose nd the wires look very bad.
This is your engine speed sender, it drives the tachometer on the dash and also feeds into the PCM that controls the transmission, again for shift schedule purposes.
Old Jul 11, 2010 | 09:36 PM
LCAM-01XA's Avatar
LCAM-01XA
Smartass - my map is on my windshield, it adjusts to my location automatically too But really the sensor in question is not a MAP (manifold absolute pressure) sensor, as it's not reading vacuum off the intake manifold like it does on a gasser truck - instead it reads the ambient pressure, hence why it's a barometric sensor.
Old Jul 11, 2010 | 09:37 PM
chicagodragon
should the hole on the baro sensor be cleaned out? i looks plugged to me
Old Jul 11, 2010 | 09:45 PM
  #28
LCAM-01XA's Avatar
LCAM-01XA
Actually mine has a white plastic funnel-looking thing at the end of that port, and the hole in it is clean of dirt and grime. How you'd clean yours I dunno tho, you can't just poke through the nastiness cause it will then end up inside the sensor... if it were my truck and the trans shifted fine I'd probably be tempted to just let it be as is for the time being, then replace it with a clean junkyard unit whenever I found one.
Old Jul 11, 2010 | 09:49 PM
  #29
chicagodragon
it dont shift that great to begin with. i bought this as a future powerstroke build, but i might leave it like it is depending on if i get everything else straightened out. take a look here... https://www.ford-trucks.com/forums/9...out-there.html
Old Aug 3, 2010 | 02:43 PM
  #30
gfemling's Avatar
gfemling
Tac Sensor
Think the sensor your pic shows is on the housing just in front of the injector pump and is the sender for the tac in the diesel.
OOPS, realized that this was already answered on next page of post
