before and after pics
#91
Received 4,169 Likes
on
I think adding those extra teeth make a world of difference, I like it. I like what you did to the side of the hood as well Mostly52f1. You were also talking about the crome moldings for the front of the hood but I like what you've got going there as well,but your not building it to suit me, so suit yourself,lol
John
John
#92
John
John
appreciate all the complements, it makes the build worth every penny and all the time. thanks
#93
on
did you see the pics in my gallery? the front end that was on it before looked horrible. a 50's fleet wood grille(the one with the bullets) and some camaro headlights. ewwww. but it was all in the junk yard to use(cant beat free with a wet chain lol). had to do somethin till i found two 52 grilles to make the one i wanted.
#95
on
#98
Yeah, Mostly 52 F1, same Dentist. He offered me this but I was way to medest:
For every part that I've taken out of a stock configuration, I have a stock counterpart.
For my grilles (with the full front tilt) I restored them at the same time, wired them the same - with common plugs, and brazed the mounting bolts to the headlight buckets inside. I have wing nuts holding them on behind the light panels. So I can swap out a grille to the 3 grille stock one in about 5 minutes.
I didn't cut the lower valance for the two extra teeth, I just cut them real close so you can't tell from any more than 3 feet away that they don't go in like the stock ones. That way I have no holes when I put on the 3 tooth version!
Did you do that too or did you cut your valance?
#99
that is a good idea, i should of did that with my teeth, but i cut the lower vallance and bolted them in like the stock ones.
and for the 7 tooth... wow, i have extra teeth.... woohaha
is it one center and 3 left and 3 right, or 3 center teeth, with 2 lefts and 2 rights? i cant tell in the pic.
#100
#104
#105
