Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Need Keyless Remote
Old Nov 23, 2008 | 07:26 PM
B 3000's Avatar
B 3000
Need Keyless Remote
Bought an 05 Escape at an auction, it came with 2 keys but no remote.
On E Bay they sell them & say they easy to progarm.
How can they be programed?
Whats involved?
Can't be
anything in there but a
circut board.
Old Nov 23, 2008 | 10:56 PM
wptski's Avatar
wptski
Normally there's a procedure like, turn the key ON, press the brake twice, open/close a door, operate door locks, etc. Procedures vary and I'm not sure their the same for all years.
The procedure should come with the remote.
Old Nov 28, 2008 | 03:05 AM
scarletlewis's Avatar
scarletlewis
If the remote is not included, I guess you have to buy it yourself and have it programmed.
Old Nov 28, 2008 | 08:51 AM
wptski's Avatar
wptski
Reading the manual for my 09 Escape it states that you must have at least two working remotes to program others. A dealer probably has other ways of doing it.
Old Nov 28, 2008 | 10:18 AM
aj7885's Avatar
aj7885
from Escape Manual
programming remote transmitters
It is necessary to have all(maximum of four — original and/or new) of
your remote transmitters available prior to beginning this procedure.
To program the transmitters yourself:
• Insert a key in the ignition and
turn from 1 (LOCK) to 3 (RUN)
eight times in rapid succession
(within 10 seconds) with the
eighth turn ending in the 3
(RUN) position. The doors will
lock/unlock to confirm that
programming mode has been
entered.
• Within 20 seconds, program a
remote transmitter by pressing any button on a transmitter. The doors
will lock/unlock to confirm that the remote transmitter has been
programmed. (If more than 20 seconds pass before pressing a remote
transmitter button, the programming mode will exit and the procedure
will have to be repeated.)
• Repeat the previous step to program additional remote transmitters.
The doors will lock/unlock to confirm that each remote transmitter has
been programmed.
• When you have completed programming the remote transmitters, turn
the ignition to 1 (LOCK) or wait 20 seconds. Again the doors will
lock/unlock to confirm programming has been completed
Old Nov 28, 2008 | 06:14 PM
B 3000's Avatar
B 3000
Thanks for all the replys. Now I understand.
4tl8ford
Oct 6, 2011 08:17 PM
429unibody
1961 - 1963 F100 Unibody
Aug 22, 2011 08:07 PM
2manykids
Dec 24, 2010 04:07 PM
