Usually it's the amp, that's what happened to me on my 2001.
I am in the process of swapping out a new sub and amp for the old stuff because the stock system is a 1.2 ohm and I don't want a stock amp that will pack it in like this one did.
You can always put a 8" sub in the old box with a new amp that has a high lvl input to connect to the head unit wires. Be aware the stock box is less than 4" deep unless modified.
No one makes one for the second gen expy's because the area that holds the sub cannot be replaced. It is not modulat like the first ones, but is molded with the side panel. A whole back side piece would have to be replaced.
A bit high? it is 70 bucks cheaper than anyone else and has a built in 200 watt d class amp. Amp sub and custom fit box with install cables and a bass control **** 359.00 not too bad.
Only problem was that they are out of stock when I phoned. arrrggg
I know I can get more bang for my buck but I was trying to save room in the back. I may break down and buy a box I hate waiting.
About the original post, maybe he can put a new amp and after market sub in.
Has anyone with a 2004 enlarged the hole and put a bigger sub in the stock location.?
When you mention all of that, no, it doesn't sound too much. But that much for something that small....I'm thinking of doing what you said, go with a bigger box to get more bag for the buck. I hate waiting too.
That is why we haven't changed the sub in our Expy. The replacements just aren't too much more potent. What really sucks though is I have to choose between having a small dual 12" box that's designed to fit between the back hatch and the back of the 3rd row seat that with amps, subs, box, and wiring will cost about 600$, or buy a small replacement sub, not get much more bass, but be able to still use my 3rd row and have some cargo room. Just not much choices abvailable for us.
Wow, I kinda like the kicker box! I can still load and unload stuff and not puncture a woofer plus it seems harder to see from the outside and the seat fits!
I committed also but went a little bigger on the sub box lol...
polk db212
I also got these for the back doors
polk db6501 6 1/2 component
Brandon, you can still take a big box in and out I am going to use quick connects.
Also, I really like these new component speakers, putting the tweeter separate really helps and you
get more bass from a round speaker.
Whichever you choose buy the 20 dollar dynamat kit for your door speakers it helps alot. One kit does two speakers.
