MAP Sensor Location?
Old Nov 5, 2008 | 01:14 PM
Fordie Fish's Avatar
Fordie Fish
Hey I was told some of my problem might be corporated in with my MAP sensor. I have a 2005 F150 and I am wondering where it might be located. It is a 4.6L any input would be great! Thanks,
~Will
Old Nov 5, 2008 | 02:11 PM
Fishin76's Avatar
Fishin76
you don't have a MAP sensor, but you do have a MASS AIR sensor that is on your intake tube between your air filter and the throttle body.
What kind of problem are you having?
Old Nov 5, 2008 | 02:20 PM
mrpositraction's Avatar
mrpositraction
Correct, you have a MAF sensor (Mass Air Flow like mentioned above), not a MAP sensor (Manifold Absolute Pressure). The MAF sensor is located between your throttle body and your filter. Mine (2008) was located right after the filter (which was right above the TB).
Old Nov 5, 2008 | 10:14 PM
Fordie Fish
Here's the trouble that I have been having. I recently posted a thread on it and didn't get any more input. I was told that the system too lean bank 1 and 2 were tripped off by a MAP sensor or from a vacuum leak. Included is the entire Thread. I would appreciate any input.
https://www.ford-trucks.com/forums/7...ome-input.html
Thanks,
~Will
Old Jun 13, 2010 | 03:55 PM
kstafford63's Avatar
kstafford63
anybody tell me where me where the map sensor is on an '04 F-250 6.0 I'm gettin an 0238 code truck is running great..
campbellpardee8
Jun 27, 2017 10:47 PM
countryboywatts
Jan 2, 2016 05:35 PM
patman247
Feb 27, 2011 09:20 PM
jayeffel
Apr 5, 2010 03:01 PM
frankyford
Jul 26, 2009 08:49 PM
