Miles on your 04-08 F150-List
  #61
Old 10-28-2008, 07:02 PM
baitmaster's Avatar
baitmaster
baitmaster is offline
'05 XLT 4WD, 16,000m, nothing but oil changes.
  #62
Old 10-28-2008, 07:59 PM
mercman86's Avatar
mercman86
mercman86 is offline
just turned 60,000 today heres whats been done since new...
-replaced rear engine oil seal @ 230mi (warranty)
-butal methal pad recall
-Installed cruise control
-added camper top
-replaced fuel door cause spring broke (warranty)
-replaced leaking stop light (warranty)
- new firestone tires
-trans flushed and fuel filter replaced @ 50,000
about to bring it in due to an inaccurate fuel gauge but other than those things the truck had been great!
  #63
Old 10-28-2008, 10:08 PM
guessrow's Avatar
guessrow
guessrow is offline
Wow, you guys need to get out and drive!!!
04 XLT SCrew 4.6
147,XXX miles- purchased @111k
I have installed plugs, changed fluids and filters.
Rear axle has a tiny bit of noise, front left wheel bearing needs replacing.
good luck -jim
  #64
Old 10-29-2008, 02:24 PM
HishersF150's Avatar
HishersF150
HishersF150 is offline
2007 Lariat SCrew 4x4 6.5' bed Loaded
28,581 Miles
No Problems
  #65
Old 10-29-2008, 05:34 PM
USMCAIRF18's Avatar
USMCAIRF18
USMCAIRF18 is offline
Originally Posted by tooldad
ADD:
5.4L Engine
Driver's door master window switch
Seal for oil filter adapter (slight leak found by tech)
Originally Posted by tylus
bolded stuff be mine
Tylus's Quote:
Originally Posted by soundwave
year 2006
trim FX4 Luxury
mileage 23,650
repaired and/or replaced
Paint defects on drivers door, passenger door, rear driver door, rear pass side of cab
Drivers door master electrical window switch
all 3 F-150 emblems
Mine:
2006
XLT Scab 4x4 Long bed
37,XXX
Brake Booster Recall
My FORD/F-150 XLT emblems are all peeling/bubbled up as well (not covered over 36000mi)
QUESTIONS:
1)My driver's window is verrryyyy sllloooowww...is it a must replace or fixable??
2)Does anyone know how to figure out keyless entry code with factory electronic keypad on door if previous owner didn't know??
  #66
Old 10-29-2008, 05:45 PM
ketchup's Avatar
ketchup
ketchup is offline
2005 Lariat SC
64k miles
Brakes, brake vacuum hose-hose under recall
  #67
Old 10-29-2008, 07:09 PM
Chrome FX4's Avatar
Chrome FX4
Chrome FX4 is offline
2004 FX4 SC
Bought with 21,000 miles
Currently 42,000 miles
- IWE's replaced
- Rear Axle Seals replaced
- Rear Brake pads replaced
- Tie rod end replaced
- New Tires
- Headlight Bulbs
Other then that just oil changes and liking this truck more and more each day!!
  #68
Old 10-29-2008, 09:28 PM
wwilson43's Avatar
wwilson43
wwilson43 is offline
2007 F150 XL
Computer reprogramed due to rough idle and lack of power
  #69
Old 10-30-2008, 12:01 AM
emik26's Avatar
emik26
emik26 is offline
2005
Silver FX4
29,500 miles and still running strong
Warranty work and some add on's.
  #70
Old 10-30-2008, 01:33 AM
acfd527's Avatar
acfd527
acfd527 is offline
if you have a supercrew, the code is behind the rear seat on a box. do a search on rear seat removal and someone here posted step by step of how to remove it. i had my dealer get it off the computer when i had recall work done. i think i paid $30 extra for it but it saved me the time and trouble.
  #71
Old 10-30-2008, 02:55 AM
pilot10's Avatar
pilot10
pilot10 is offline
Caution: may cause nightmares
06 King Ranch
Dk Copper
Loaded
Purchased 10/06 w/ 8,400
54,600 in 6/08 when traded in
4 rear ends(last one included complete housing)
2 rear pinion seals
2 axel seals
EATC "head" unit replaced
wiper motor (shorted out due to E-brake foot pedal wearing thru wiring harness)
4x4 motor & solenoid
Brakes - Rears @ 22k/ fronts @ 28k
rear end leak
Door rattle- electric window motor came loose(replaced prior to me owning truck)
Everything was covered UNDER WARRANTY, even the brakes- I did purchase the ESP w/ about 35,900 miles and used it once to replace the rear end & housing @ 51k
There are a couple more warranty issues I can't remember w/o checking records- it was in 15+ times in 22 months of ownership. When I traded it in 2 windows and the sunroof had intermittent electrical issues and the brake hose recall was just hitting the mail-box. As for the lemon law- it didn't qualify..... too many miles when the problems started.
The day I made the last payment on my 01 Lariat - in perfect shape w/ 137k, I traded the it in for the KR. The wife said I was crazy- it is so annoying when she is right. I sure hope the 09 or 10 I'll buy will have less problems
tim
  #72
Old 10-30-2008, 08:45 AM
johnnycool's Avatar
johnnycool
johnnycool is offline
2004 Lariat crew, 2wd 5.4
41,460 miles
replace battery--warenty
windsheild--rock
  #73
Old 11-01-2008, 11:32 AM
Pahrump1's Avatar
Pahrump1
Pahrump1 is offline
Bought new in late 03.
2004 FX4 Super Crew Yellow
190,000 No real issues till now, truck has started just dieing when it wants to, threw a bunch of IAC and Throttle body codes, I took the throttle body off and it was HELLA dirty, cleaned and it seems better so far.
  #74
Old 11-01-2008, 03:10 PM
ChargersFanInCO's Avatar
ChargersFanInCO
ChargersFanInCO is offline
2008 Lariat
ummm...7,800 miles. I drive a work van.
  #75
Old 11-01-2008, 07:31 PM
white04f150's Avatar
white04f150
white04f150 is offline
Mine:
2006
37,XXX
QUESTIONS:
1)My driver's window is verrryyyy sllloooowww...is it a must replace or fixable?? Depends on what the problem is, If it is somthing like elctrical then yes it is fixable, if it is mechanical then you might as well just replace it.
That's just my two cents tho.
2)Does anyone know how to figure out keyless entry code with factory electronic keypad on door if previous owner didn't know?? [/quote]
Quick Reply: Miles on your 04-08 F150-List
