Torque Spec Needed
Old Oct 19, 2008 | 09:15 AM
2003 6.0's Avatar
2003 6.0
Torque Spec Needed
I need the torque specs for the bolts that hold the cover on the water seperator. I'm taking it off to see if I can clean the water sensor. My light won't shut off after draining it 3 times.
Old Oct 19, 2008 | 12:00 PM
PowerStrokeHD's Avatar
PowerStrokeHD
Manifold cover screws are 5 Nm (44 lb-in). It is also suggested a new manifold cover seal be installed. More info can be found at the link below...
03-WSM
