The truck was manufactured 10/95. Any input would help. THANKS!!!!
Sounds like a 1996 truck so it would depend on the GVW and the engine size.
If you have a 5.0 then it would be OBDII.
If you have an 5.8 then if it is under 8500 GVW it would be OBDII.
If you have an 5.8 then if it is over 8500 GVW it would be OBDI.
An OBDII truck would have a plug under the dash and a OBDI truck would have the plug at the LH drivers hinge.
