Anyone else not get consistant boost from their turbos?
When my truck seems to run great... I average 30lbs boost. Sometimes I see 33/34lbs. But, typically, I don't get more then 21lbs and I feel like little old ladies in VW Bugs can easily take me.
Get the new PCM software! It is a night and day difference from what you're describing. Sounds like you are in regen mode with the low boost and low power.
Max I typically see is 32psi. I have only once seen 40psi. It was up a long steep hill with a small utility trailer and a few ATV's on it. It was at 40psi and held there consitently until I crested the hill. Although now even with 7k lb trailer attached I only see 32.
