Mini Message Display Help
Old Sep 23, 2008 | 09:59 AM
B_D's Avatar
B_D
I have a 06, F150 and the Mini Mesage Display that shows the mileage, trip odometer, low fuel, etc. stoped working the other day and remains blank.
Has anyone experienced this and/or knows what could be the problem?
Thank you for your response.
Old Sep 23, 2008 | 09:05 PM
Franklin2's Avatar
Franklin2
Make sure you check all the fuses.
Old Sep 24, 2008 | 12:38 PM
B_D's Avatar
B_D
I checked out the fuses and discussed the problem with a dealer and an independent mechanic. They seem to be in agreement that it is probably a computer issue with the instrument panel itself. Will know alot more by Monday. Thank you for your reply.
Old Sep 30, 2008 | 11:18 AM
B_D's Avatar
B_D
What I've found out is, apparently the instrument cluster has one of several computers that are on the truck and it is faulty. That is why the Mini Display Panel is out. The instrument cluster has to be sent in so the information from the old one can be burned in to the new one, info like current mileage.
The truck can't be used at all untill it is replaced.
jonkoby
6.4L Power Stroke Diesel
May 20, 2011 05:09 AM
rouschfan
2004 - 2008 F150
Dec 19, 2008 07:03 AM
B_D
New Member Introductions
Sep 22, 2008 03:50 PM
Abbie
2004 - 2008 F150
Nov 11, 2007 11:06 AM
