'91 7.3 engine problem?
Old Sep 10, 2008 | 08:51 PM
mechmagcn's Avatar
mechmagcn
The issue with a Stanadyne pump wanting to stall when dropping from high speed is usually from a sticking metering valve. Try running either DK or Stanadyne lubricity formula through it and the problem should go away.
Old Sep 10, 2008 | 10:49 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Filling an empty filter with Diesel Kleen will not hurt an IDI IP.
And it will start just fine.
It will idle a little funny for 30 seconds or so, but the that is just the rest of the air working through the system.
Back in the old days I used ATF, but addatives like Diesel Kleen were not as available as they are today.
Consider a quart of ATF will treat a tank of fuel.
A quart of Diesel Kleen will treat 300 gallons.
So for regular use, Diesel Kleen is cheaper than ATF.
Using a strong concentration like filling the filter with Diesel Kleen does cost more, but it also will clean and lubricate the IP better than ATF will.
91 Super Duty
Aug 24, 2011 02:35 PM
oldblue89
Nov 25, 2010 12:20 AM
hilljackusmc
Dec 18, 2006 08:35 PM
Lockedhearts
Mar 16, 2004 05:05 PM
goody
Sep 13, 2000 03:00 PM
