Camshaft upgrade
Old 08-26-2008, 09:12 PM
DesertStorm's Avatar
DesertStorm
DesertStorm is offline
Camshaft upgrade
Will a .450 ish lift cam work with an EFI setup? What fuel mods would need to be done, new chip, etc.?
Old 08-29-2008, 09:49 AM
Conanski's Avatar
Conanski
Conanski is offline
If you have a mass air motor it will adapt to a wide range of cams no mods necessary, with SD the choices are much more limited. What cam are you looking at?
Old 08-31-2008, 10:43 AM
DesertStorm
i will get the grind number. I believe it was 468 lift with 265 duration at .5inch
Old 10-09-2008, 03:48 PM
Old Rob's Avatar
Old Rob
Old Rob is offline
Lift is ok, however that's a lot of duration @ .050 for a street engine.
Contact tech at Automotive Component Engineering
Old 10-09-2008, 07:41 PM
DesertStorm
thanks ,good site
bradphx
67
01-10-2024 06:12 PM
03-09-2016 12:40 PM
Aerostar
01-14-2015 03:16 AM
miko6810
Modular V10 (6.8l)
06-04-2014 06:14 AM
02-20-2014 06:51 PM
Quick Reply: Camshaft upgrade
